racerbob
this engine and trans came out of a 65 barracuda I am parting out. The car was not running when I got it (had not been on road for 25 years).
Engine does turn over and is a good canidate for rebuild/parts (or maybe even get it running and use AS-IS). Engine comes with manifolds. carb, dist, etc installed. Offered as a rebuildable core at $50
Transmission is a cable shift 904 unit (car had the OEM floor shifter). I removed the pan to disconnect cable, when I did I discovered trans looked very good inside. I think this unit will work as-is, but since i did not get a chance to run/test drive it. It is offered as a rebuildable unit at core price $50[/I]
or buy the pair for $80 OBO
Items located in La Plata, MD local pickup only.
I will try to add pictures later.
Bob
Bob
