71twister3bytheknee6
My 170 '69 Dart appears to be missing the rear flanged manifold heat control valve bushing.I might have damaged it when I was trying to free it up for 3 days.The steel shaft now appears rather loose and sloppy in the cast iron,and I am concerned it might leak exhaust gases.The front bushing is fine.Does anybody know what this is made of,steel,stainless,brass,etc.Is their a standard size number I can use to request it in trying to find one?And if I find one,will I be able to slip it over the rear end of the shaft,into the cast iron.I will certainly find something to use as a proper hollow circular punch.Ofcourse I'm also missing the retainer clips that fit on the shaft.If anybody has any of the above bushings and retainers,and anti-rattle spring,I'd be more than happy to pay you to take them off your hands. Thanks. Any info would greatly be appreciated.
