Rich2000
Member
I'm selling a 6 pack setup for a 340. The part# shows it's a 1970 setup. I was told there is a difference between the 440 and 340 air cleaner. I basically need help in determining if what I have is correct to the rest of the setup.
Not 340. Mine is picked up but Shakerhood.com formally Ben Snowbar ( who I knew ) site shows a picture of the bases. Here's a shot the fresh air vents that are removable block off plates.
There were no 340-6's in 71.. 1970 only.. T/A & AAR only...What about 71?
No. 1970 only again only 340six in AAR-T/AWhat about 71?
I have you shakerhood.comSo there was never a 340 6 pack application without a shaker scoop, or air grabber? What does the base I have belong to?
1970-1971 440+6 without a fresh air hood.So there was never a 340 6 pack application without a shaker scoop, or air grabber? What does the base I have belong to?
Thanks for the info.1970-1971 440+6 without a fresh air hood.
B, C and E body
I appreciatethe help.I have you shakerhood.com
diff you do any research the 440 ones. Also Tommy has a great site and top notch parts E body rubber bumpers and many
air cleaner
tommythecryo
440-6 pack - Tommy The Chryco
Yes I did. It took me a little bit but I get it. Thanks again!No. 1970 only again only 340six in AAR-T/A
Your base is 440. Fresh Air as has shield.
Did you look at the bases in the link I supplied?
