6 pack air cleaner base 1970 340
Rich2000
Porterville, Ca
I'm selling a 6 pack setup for a 340. The part# shows it's a 1970 setup. I was told there is a difference between the 440 and 340 air cleaner. I basically need help in determining if what I have is correct to the rest of the setup.
Only 340six packs were 1970 AAR and Challenger T/A seals to fiberglass hpod 2 fresh air removable metal vents in rear. Clearly not the same as a 440 six.
A quick look at a picture of yours would help.
You can alsp see clearly the lip that seal the TA / AAR goes on. The seal goes on the base not the hood
So there was never a 340 6 pack application without a shaker scoop, or air grabber? What does the base I have belong to?
You are not understanding. No 340six other than 1970 AAR Cuda and T/A Challenger. And had fiberglass hoods. The T/A hood AAR hood.
The lids also had a Wide Lip.
1970-1971 440+6 without a fresh air hood.
B, C and E body
