Picked up what I thought was a 4792 340 center carb at a estate sale along with other misc 2 barrel carbs (cheap)
When I got home and further inspection it turns out this carb is a 4782 (DC mechanical) with the base plate and fuel bowl swapped with the 4792/91 pieces.
Going to tear it down to ID internal parts
Now my question Can this carb be used with Vac Sec end carbs as is or ?
Only issue I see is the bowl vent linkage arm is misaligned
Plan on storing the carb for now
I do have a 6 pack set up to use on my 340 dart 4sp 391sg in the future
Any advise/thoughts?
Thanks
Thanks
