/6 Power Improvements
Jim Kueneman
Sonoita, Az
If you want real data in choosing your /6 upgrades I plotted the data from this article:
Slant Sickness! How To Add 77 HP To Your Mopar Slant Six! - Hot Rod Network
It seems to me the Dutra Duals are cools looking but for the bang for the $600 buck is not there for me in the typical cruising RPM but letting it breath has a HUGE benefit.
nice article!! i got some manifolds half the cost same performance if your interested. Going dual was a great choice for my slant
Split the factory intake front of stove aka "Dutra econo rear". Weld the front 3 closed and add a flange at #2, use the welded closed rear flange as is.
I take that the Stock Torque & HP numbers is with a 1BBL?
Pista, can you post a pic of the intake?
thanks
This was Doug Dutras concept before he cast his own. Worked pretty good but shorty hyperpak header deaign would work better if your not interested in carb heating.
