Woods74
Broke Senior
Hey all, doing a 1974 Dart Swinger. Installing motor mounts, running into the K member having a bit of a problem finding level.
Variables:
I'm using the valve covers as my straight edge.
The rear end suspension is raised, some 1-2 Inches in the back.
Is the final level:
#1 Car level on a absolutely perfect surface, regardless of the fact the rear end is up or down?
#2 Running a string 'X' on the frame rail, under the floor board interior of the car, then transferring that mark?
#3 Eye ball or string ran when suspension and tires are level, then leveling engine?
How critical is all of this? What point IS level for the engine?
I get the feeling I need to shim the tranny mount for height as it stands now, something doesn't blend.
Need some guidance, fresh ideas, and some muscle!
Hope the Weekend treats you well. :thumblef:
Variables:
Is the final level:
