2 tabds on the choke? Then one is a positive "Hot" wire that needs a switched 12 volt source. (Hot when the key is in the run position and ocold/off when the key is out.)
The other is a ground.
I do not often see a 1 wire electric choke, but there out there. It's just a hot wire to a self grounding choke houseing.
