What’s the best rebuild kit for the 6190 holly carburetor, And where should I get it from? The last couple times I’ve gotten stuff at the local auto parts store it’s not the right item I need. Is it better to order the carb kit online somewhere? I’ve noticed that it’s not a carb number that they list, The kit must work for 10 other different carburetors.. Also, isn’t this a 650 vacuum secondary carb? your opinions??!
Are you sure you are looking at the list number, and not the four digit manufacture date? I cant find that list number in my holley list either. Can you post pics? The LIST-XXXX-x is the carb i.d. number. A four (or three, for an old,old carb) digit number under it, is the build date. [ATgyTACH=full]1715617562[/ATTACH] This is a 4781-3 850 double pumper.
I am in the shower, or getting in the shower now because I smell like gasoline. I’ll go out and take a picture of it later. These are all I have now
That is a list number 1850 600 CFM universal fit vacuum secondary 4160 carb. I get my kits from Mike’s carbs. Tell them the list number and you’ll get the right kit.
Yep, any quality 4160 carb kit will cover that carb, it is the most common-as-dirt holley carb ever made. I have been very happy with Jegs brand carb kits, i used three of them recently.
Okay Thanks. I have not rebuilt a carburetor in the past 12 years or so, but it has been 20 years since I think I put a kit in a Holley 4bbl carb .
