bridger5228
Would a 727 out of a '63 Fury with a 383 be a good choice to use in my '71 Duster 440 swap? I found one that I can buy for $100
That would also be a pushbutton trans .
Thank you for the great answer!
No. Get a 71 through 73 model if you can find one. After 73 they went to a load controlled front servo which isn't as good and a lot of them only had 3 pinion planetary sets vs. 4 in the older ones.
Can you please elaborate on why the later 727's are not as good for performance? I just installed a drivetrain which includes a later model(1979 ish) 727 in my dart. I am curious as to what will be different about driveability with a later model 727?
