63 valiant carb
i have a 63 dart whole parts car was running when parked with no oil pressure 20 so years ago carb surely will need kit but should be fine 20.00 plus shipping seems fair to me sandy
I should have something that will work too but mine should probably have a kit put in also. Do you want a Holley or Carter? Do you need the correct one for that year or just one that will work?
have a holley in it now. just need some that will work. how much for the holley?
Did you get your carb, the 63 is smaller than the 65 (went to the 225 size that year I think, maybe SS Dan knows)
I went through all my carbs and can only find a Carter.......no early Holley 1920's at the moment. If you want to try a Carter, you'll need to modify the fuel line a little as it goes into the front of the carb instead of the side and the PCV hose might be a different length. Otherwise, it should be a bolt-on.
