rustytoolss
Got the heads off my early 273. Never had a 273 apart before. At some point in it's life someone installed open chamber 675 heads and hydraulic parts.
Back to the pistons. They are flat top , with 4 valve reliefs. Look to be .050 in the hole. The pistons are stamped .030.
I'm guess that I've got the 8.8/1 pistons ?
Also how far can I safely mill THESE 675 heads to up compression ? was also thinking of using MR Gasket .028 thin head gaskets. This is just a driver. Would still prefer to use 87-89 octane. Any input
