64-66 Barracuda trunk props
stoke
monroe, WI
How many different types of trunk props were there for the 64-66 Barracuda. I have one that is spring loaded, with hooks on both ends, where does this hook up on the trunk and body? I bought my car on E-bay and it had no prop at all.
Thanks, Stoke
64 / 66 HAD 2 DIFFERENT TYPE OF TRUNK PROPS,,,64 AND EARLY 65 USED A RATCHET TYPE,,AND LATE 65 AND 66 USED THE TYPE YOU Have that cylinder with a spring in it,, on the trunk lid is or should be a hole on the left side wit ha shroud aver it that the hook goes in to,,, the juat a hole on the left rail under the trunk lid,,,
