64 barracuda
Shippy
Member
Walnutport pa
Looking for a power brake booster for 64 barracuda any one have one ????? The one that i have is 8 inch diameter, and single master cylinder , it definitely took a crap
If you are converting to a dual master cynlinder, then any A body booster after 67 will fit. If using the same as what you have, send your booster to Booster Dewey in WA state. Also make sure your vacuum tank holds vacuum
