64 cuda original rear end
Garry
Louisville,ohio
wow a 7 &1/4 posi, must have been an option, dads car bought new ,know it's original. was there a special gear lube for this animal? also anyone know where I can find 1.5 front bearing caps?
NAPA has a GL-5 API Service rated gear oil 80W-85W-90 that is for limited slip differentials. They also sell a "friction modifier" that is intended for limited slip differentials.
I used both together in my 65 Dart 7 1/4 suregrip differential after rebuilding it with new bearings & seals & adjusting/tightening the pinion/ring gear backlash to specs by replacing the spacers.
I'd recommend you pull the cover, clean things up, & check the backlash before investing in the fluids.
Is your pinion seal leaking?.....another item to fix before investing in fluids.
How can you tell if you have a sure grip or not? Mine is in a 65 Formula S.
Thanks, I'm still learning
If the rear is in the car use a floor jack under the center and lift both tires off the ground; spin one tire and watch the other tire:
1) if both tires spin in the same direction it's most likely a suregrip
2) if the tires spin in opposite directions it's not a suregrip.
Most suregrips have a special suregrip lube plate bolted to the rear
