Not sure if you mean the reverse switch on the trans or oil pressure sensor on the rear of the engine but either should be a parts store item.
It is a little plastic screw in plug with a couple of electrical wires into it into the housing of the manual transmission and it is leaking fluid significantly
That's the reverse light switch & it's a cheap auto parts store item. If they don't have a listing for a 64 just use a later year, say 1970, it's the same part. It seals with a gasket.
Did you try taking it out, cleaning the threads, wrapping it in teflon tape and screwing it back in?
http://www.napaonline.com/Search/Detail.aspx?A=MPENS6571SB_0165506720&An=599001+101970+50056+2056018
You can usually find these NOS as well without much problem.
http://cgi.ebay.com/ebaymotors/62-6...rcycles_Parts_Accessories&hash=item22fe76373e
The NOS will probably work & the aftermarket part might work. :toothy10:Is there a difference between the NOS and the napa part?
http://cgi.ebay.com/ebaymotors/62-63-64-65-66-67-68-69-70-71-78-NOS-MoPar-BACK-UP-SWIT-/150298048318?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item22fe76373e
Well worth the aprox $30 shipped, for the NOS Ebay one.
http://stores.ebay.com/AMS-Obsolete-Formerly-Mitchells
