65 273 heads
65Vart
Waterdown, Ontario
Does anyone make a set of intake bolts for the 65 273 head? I believe they are smaller then 3/8 (5/16). Also I need the thermostat housing pipe fitting (to the water pump) as well as the one to the heater hose. finally installing the new" D4B intake I got 5 years ago).:blob:
Where can I get these? Thanks in advance.
I don't see why hardware store bolts (preferrably painted) wouldn't work.
Go to a bolt store, get grade 5 ("Y" on the back, or "3 point") bolts
