Got a set of 65-72 lower control arms with the sway bar tab out by the lower ball joint. They're going to need to be blasted and painted (or powder coated) and most likely a new pivot bushing installed. Re-use your control arm bumper.
Since these control arms have the sway bar tab, you'll need a sway bar. Included is your choice of 1 of 3 different sway bars. From top to bottom: the Hard-to-Find early A 65-66 Formula S or HD suspension in the Dart sway bar; the 67-72 sway bar or an aftermarket 1 & 1/8 in sway bar that appears to be the same width eye to eye as the 67-72 factory bar (no mounting hardware with that bar.
Your choice of sway bars plus control arms $250 plus shipping from 22657.
