stroker402
1968 dart GTS convertible
I have a 65 formula S with factory tachometer . when I start the car the tach needle pins all the way to right. when I shut the engine off the needle will fall back to "0" again . I do not see any wire that is suppose to attach to neg side of coil . was told it is suppose to be a grey wire . the sender unit is above the kick panel where it should be with all the wires (4) attached to it.
Can anyone tell me or snap a pic of which terminal block it goes into . upper or lower etc. my 65 formula s tach but has no wire going to the coil.
Question :
Is that coil wire in the wire harness ? or is the wire separate coming directly from the bulk head block to the coil ?
here are 3 pics I found of the 65 barracuda tach and wires.
I can't see where the wires go even by enlarging them . my eyes are bad maybe you guys can make it out. I see two wires that have masking tape on them too , maybe where they go ..
Thanks guys for any info !
john
Question :
john
