"65 Barracuda fenders on a '65 Dart
A/MP
Found a company that has fiberglass fenders and hood for a '65 Barracuda. At first glance they look like they would fit. Saw this set up 30 years ago but don't remember how the fit and finish was. Door lines a problem? Thanks
ok a stock set for barracuda finders will fit on ur dart and look good as for the glass ones i have no ideal
Who makes thr '65 Valiant/Barracuda fenders? Does anyone make reproduction steel ones?
You will also need the hood and front vallance.
Rockerdude is correct. You can put any '63-'66 A-body front end assembly on any '63-'66 A-body, and the body lines will match up just fine, but the mix-and-match interchange is narrower. '63-'64 Dart fenders will swap, as will '64-'65 Valiant/Barracuda fenders (possibly also '63, not sure). That's about it for single-piece interchange. See Doug Dutra's Dacuda here.
