65 Barracuda Rear Deck Trim
eengledow
Member
Oklahoma
What is the easiest way to get the large trim and logo removed from the rear deck?
Thanks!
From the inside, remove the covers at the base of the rear window. There you will find the openings to get to the screws to remove those. Use an deep socket to reach inside. Keep up with the nuts and there are 2 small pieces that you need when you put it back togeather. Not sure what you call them, but you will know what I am talking about when you take the off.
