'65 Barracuda Rear Window Steel Trim Installation?
dibbons
La Paz, B.C.S., Mexico
Any tips/info before I attempt to install the rear window trim? I don't have access to the new foam/rubber seals (I have the old/original stuff only) Last photo (installed) not mine. Thank you.
pop em off, pop em on. The real trick is getting to the nuts if they are behind that plastic trim piece. The mounting screw is under the windshield gasket. I didnt even know these gasket were available.
I just bought some similar white foam from Lowes, matched it up with the original stuff. It does take some patience to get the little cupped washers on with the nuts. And if you drop them in the frame work it is extremely difficult to get them out. I know!
