[WANTED] 65 Barracuda sheetmetal
swing69
I’m just an old guy……
Central NJ
For my HS project car in central NJ:
The RR qtr (back corner) took a hit many years ago - the tail panel and RR qtr. are kinked. We don't have a way to pull them... We are leaving the "patina" so rough body work is good enough.
I'd like to replace the tail panel and trunk lip from just right of the lock to the tail light. Anyone have a 65 they can cut this piece from? also....maybe all around the right tail light housing section. we can cut a piece it to fit Its SO kinked, no hope of really straightening it.
how would you repair rust through above the pass. door striker? anyone have a section to fit this cut from a car?
Picts are in my post in the early A bodies forum. I can send a pict with more precise cutting info....
thanks....what do you have????????
thanks lee. replied. 'cmon fellas....,need the cuda tail panel and rr light area!!!!! :)
"cmon...someones gotta have a gutta 64-65 sitting around. I'm sure the part I need is still on it! bueller????????
PM me if you have one to cut up!
Lee: going to look CLOSE at what I have on Monday when back at school and let you know on the striker panel.....thanks for your patience......Mike
Holy cow!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have what you may be looking for but based on your comment on my post, you probably don't want to buy from me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Let me know if you do, or not
huh??? did I comment on a post??? not sure. anyway. thanks...but I have one "in the post" right now. thanks...Mike
