65 Barracuda Stock manifold installation fitment
JeffreyLee
1965 Barracuda
meridian Id
I just re-installed my 318, stock motor mounts and factory power steering box. The problem I'm having is twisting the drivers side manifold down into place. Do I need to raise the engine or disconnect the steering column from the PS pump? I can't find an opening big enough to accept the manifold collector. Am I missing something obvious?
I forgot to put mine in before lowering the engine and had to raise the engine back up to slide the manifold in.
I remembered something about raising the engine in order to get headers to fit....Tried that trick and it worked like a champ.
Thanks
