[Found!] 65 Barracuda wiper motor
I may be mistaken but i’m only seeing two wires which means that is probably for single speed wipers?
If you have the variable speed wiper switch with it’s unique wiring connector and wiper motor with its two little wiring harnesses, it’s pretty easy (relatively) to convert from single speed.to vsriable speed. There are either 5 wires - 4 in pairs to the wiper motor and 1 wire to the fuse box. If you have an electric wadher pump then there are 6 wires coming from the switch. The 6th wire routed through the bulkhead connector to the washer pump
Is this what you need?
