65 Dart Dual Reservoir Conversion Kit????
harrisonm
Topeka, KS
I have a friend with a 65 Dart GT Convertible. It is a really cool car. Factory /6, buckets and 4 speed. He wants to convert to dual reservoir brakes. Does anybody provide / sell a complete kit? If not, what is his best option?
Thanks in advance.
Thanks in advance.
Don't know about complete kits. But browsing around this forum found that the following should fit 63-66 models.
Just ordered these last week for my 1963 Dart, supposed to fit with no modifications;
Raybestos 36221 master cylinder
MFG70662 Inline Tube splitter block
Get the parts for a '67 model. It fits reasonably well. Get a master cylinder to match up with the type of brakes you are going to use and reuse your existing pedal push rod. If this is also a conversion from drum to disc, or, manual to power, you'll need some other parts to go with it, such as a proportioning valve, booster, brackets, etc.
Remember the front bowl goes to the rear and the rear bowl goes to the front with the brake lines .if im wrong please correct .
100% agree. I'll add just a bit.
With a tubing bender and a double flare tool, you can make your own lines, with the caveat that the fittings on the lines you get in parts stores these days don't have the correct threads (unless that's changed since the last time I bought any). But the correct fittings are available. Ehrenberg, for one, sells them on ebay. A roll of bare line will give you all the line you'll need and more. However, the kit is easier, albeit more expensive. I used a 69 Barracuda kit in my 63 Valiant, just because I already had it. I had to hand bend the firewall line from the right front brake to splitter just a small amount to fit, even though the Valiant engine compartment is narrower than a 69 Cuda's. The M/C lines fit perfectly as is. Can't remember about the left front brake line, whether I used the 69 or just made a new line. As for the splitter, you can get a fitting that does just that, or you can swap in a later combination valve, which is what I did. They are available new.
On my 65 Barracuda, I made the lines myself, because I had to re-route them to clear the TTI headers.
One thing, the splitter (down on the frame) is in different locations in different years. If necessary, they can be moved, or, again, if you have a double flare tool, it's easy to shorten a line if you need to, and minor bending can be done by hand - you don't even need a tubing bender.
Finally, the little rubber lock rings that go onto the pedal push rod where it goes into the m/c are available new. I think I got mine off ebay, probably from Ehrenberg. I'm sure there are other sources.
I've done a (manual disc brake) swap twice, first a '65 Belvedere and then a '64 Barracuda. 15/16" master and 4 to 2 bolt package from Dr Diff, with a manual prop valve for the rear line. I bent up my own lines with Ni-Cop, super easy to make. Works nicely in the '65, haven't gotten the Barracuda up and running yet. One thing to watch for; the port on top of the distribution block, where the original line from the master tied in, is for a 1/4" line. A fitting for 3/16" brake line will fit, but the contact surface area on the flair is, IMO, way too small. There is a 1/4" to 3/16" adapter for this issue.
