[WANTED] '65 Dart Wagon RH Mirror
mammlouk
Colorado
Rating - 0%
0   0   0
Okay guys, hopefully someone here has what I need laying around. I was hoping to find the mirror laying in the car somewhere, but no dice. I have a mirror post/base installed, but the actual mirror is missing. I'm posting an image so you can see what the base is on the original and I can get the correct match.
That is actually an aftermarket or other brand base as right side mirrors were not factory offered. A lot of people added the factory twin post since it would fit either side.
Well that's a bit disappointing to hear. I was really hoping to complete this mirror as I'm sure it's been there most if not all of the car's life. I guess I'll measure the hole spacing to see if I can directly swap a twin post. Otherwise since it was not a factory option maybe I will be irresponsible and just delete it. :D
I may have a mirror head that might fit it
That would be terrific! Here's a pic from the mirror mount side. It has a washer on it and a threaded center bolt of some sort. If you think it'll fit then just let me know what you want for it.
That is pretty close. My mounting holes are at 3.25". Thanks for checking.
