65 Gasser?
I think one of the hot setups is to use the A100 and A108 Van straight front axle, but what all it takes to do it, I haven't a clue. If you have the coin, Speedway Motors sells a variety of straight axles and kits. You can get one of those in whatever custom width you need. Of course, they ain't cheap. lol
You Tube Videos. Quite a few.Speedway does one too.
I looked for a set up for my 63 Belvedere as I was thinking the same as you.
There is a web site called Thompson's Garage that has gasser kits/parts.
If I remember it was going to cost about $1700 to $2000 with brakes when all said and done.
Only complaint I read about with Speedway was some guys didn't like that the leaf springs were short.
They may be just right for a early A though.
Steve Magnante recently posted the videos he made a while back of his altered wheelbase gasser early Dart on Youtube. It's a good series! The build was also highlighted in Hotrod Magazine as well if I recall correctly
Here's part 1:
Am using an axle off of a '69 ish Dodge van. Had to narrow it and still need to finish steering linkage. I don't like straight tube axles, wanted a dropped I-beam. Definitely more work, though. Also tight clearance between fender well headers and front tires could be an issue. My mock-up runs 14" low profile tires, and it's still tight.
Can you show some progress pics? I have 2 8.75 rears from C Bodies so was thinking of using one of those to get that wide gasser look?
Be careful of these import "speed something" straight/ dropped axles. Some time back someone posted an accident involving a "hot rod" that axle broke off like a toothpick. Cheap cast iron.
Sure, give me a couple days. Just shoved the car in the corner to get my oldest boys project Scamp in. Mine has a B-body axle in it now, initially had a '72-3 Mustang 9" in it. With perches on top of axle, of course !
d1 is likely too wide. How about an early Econoline van? Or maybe an earlier pickup. Some of those were narrower.
Narrowing a D100 or A100 axle doesn't seem like that big of a deal. If you can find one for cheap, I'd probably just go that route.
We used an Econoline axle. Took five inches out of the center. Built a jig to bolt through the spring pads. V the piss out of it and rooted it back together. Has been abused by several wheels up launches, still holding strong. Plug/strip welded some 7ga. steel on the frame rails for rear spring hangers. Ran some square tube out the front rails to hang shackles. Welded in some mitered square tube for engine cross member. Eliminated the factory K altogether. Welded some plate from rail to new engine cross member for stock steering box in stockish location. Has a rear steer drag link to passenger side steering arm. Used a conglomeration of home made brackets, 10 1/2 inch slider caliper brackets, and 87-91 Dakota 4wd front rotors. Car in question is in my avatar. We call it, the Carp. Ugly *** freshwater fish.
Do you have
Any buildup pics?
Here's part 1:
There's a book too, it covers an early Nova, the Esserman Dodge, and a Ford Fairmont.
C445%2C290%2C400%2C400%2CAmazonEmberBold%2C12%2C4%2C0%2C0%2C5_SCLZZZZZZZ_FMpng_BG255%2C255%2C255.png
