[FOR SALE] 65 Plymouth Barracuda Formula S
Mopar Automobiles For Sale
Thread Status:
Not open for further replies due to lack of activity. Consider opening a new thread instead.
  1. neonrt_98
    neonrt_98 Well-Known Member
    84
    44
    Dec 3, 2019
    Ravenden, AR
    Local Time:
    7:03 AM
    Contact Seller
    I have original window sticker and some other paper work that came with car when I bought it. Car was a high school shop class project so body work isn't all the good. Car is mechanically good just needs body work. Car has had a lot of stuff replaced on it throughout the years. Recently installed new sending unit and headlight switch. Has had fuel tank replaced, brake & fuel lines, exhaust, rearend changed to LBP, LBP disc brakes, Mopar rallye wheels w/BFG tires, KYB shocks, Champion aluminum radiator, electronic ignition, rebuilt 318, Comp XE262 cam, Streetmaster 318 intake, Holley 600 carb, and transmission is currently getting rebuilt. Factory tach is missing. Car runs and drives great, I wouldn't be afraid to drive it anywhere.
    $6500
    blue barracuda.jpg blue barracuda 1.jpg blue barracuda 2.jpg interior.jpg interior 1.jpg engine.jpg engine 1.jpg Disc brakes.jpg gas tank.jpg Exhaust.jpg
    • Like Like x 3
    • circlepilot
      circlepilot FABO Gold Member FABO Gold Member
      887
      682
      Nov 15, 2014
      El Dorado, Arkansas
      Local Time:
      7:03 AM
      Different engine...318? Not the original 273. 7.24 rear end?
      Norm
    • neonrt_98
      84
      44
      Dec 3, 2019
      Ravenden, AR
      Local Time:
      7:03 AM
      Yes the high school put a rebuilt 318 in it. I put the Comp XE262 cam & Streetmaster 318 intake on it. And the they put a LBP 7 1/4 rear end in it.
      • Thanks! Thanks! x 1
      • YY1
        YY1 Well-Known Member
        7,564
        3209
        Oct 11, 2011
        FL
        Local Time:
        8:03 AM
        Can you show us the bad body work?
        In your opinion, does it need replacement panels?
        Is it an original blue car?
        Fender tag?
      • neonrt_98
        84
        44
        Dec 3, 2019
        Ravenden, AR
        Local Time:
        7:03 AM
        Thread Status:
