[FOR SALE] 65 Plymouth Barracuda Formula S
neonrt_98
Ravenden, AR
I have original window sticker and some other paper work that came with car when I bought it. Car was a high school shop class project so body work isn't all the good. Car is mechanically good just needs body work. Car has had a lot of stuff replaced on it throughout the years. Recently installed new sending unit and headlight switch. Has had fuel tank replaced, brake & fuel lines, exhaust, rearend changed to LBP, LBP disc brakes, Mopar rallye wheels w/BFG tires, KYB shocks, Champion aluminum radiator, electronic ignition, rebuilt 318, Comp XE262 cam, Streetmaster 318 intake, Holley 600 carb, and transmission is currently getting rebuilt. Factory tach is missing. Car runs and drives great, I wouldn't be afraid to drive it anywhere.
$6500
Can you show us the bad body work?
In your opinion, does it need replacement panels?
Is it an original blue car?
Fender tag?
