Still I can't start my engine with the key switch and there still is no oil light when I turn the key to ACC at all. Just a flicker between off and acc. I've verified my wiring connections are hooked up right and I'm not able to locate any visible problems with any of the wires concerning the circuits affected. The only way I can try to start it is by arcing the starter relay on the firewall. I replaced the ignition switch and lock cylinder just in case when I did everything. 2nd new starter relay. All new wiring under the hood. The wiring under the dash is in good shape and all proper colors are in the right place. I tried jumping the ground terminal on the starter relay to rule out a bad neutral switch but nothing changed. Tried starting in all gears and nothing happens. For the oil light issue, I tried unplugging it under the hood and grounding it but no change. When I turn the key to start there is no sound at all. Seems like a ground issue but where would it likely be in order for these too problems to occur. The ignition switch doesn't do anything and the oil light doesn't do anything, both tied to the ignition circuit. All the lights work and it does turn over when I arc the relay just doesn't start. I think it's been sitting too long with the gas in the tank. It's got spark and the base timing is right on.
