65 valiant door window gromet
JimMac
Campbell River B.C. Canad
Does anyone know a source to purchase this piece that goes in the hole in the door windows in my 65 valiant convertible? Also there is a pin on the window winder that goes through this piece and is there any kind of clip to go on the pin to hold it there? I took this apart 4 years ago and now have no memory of what it looked like before that.
Yeah, it's still the right one. I left out the window part. Sorry about that. It'll work. I bought the same ones for my 64 sedan.
I have a 66 sedan parts car and will see if it has that and if it will work. I think the sedan only has one arm raising the glass and has the metal bracket attached to the glass. My convertible has 2 arms one of which is attached to a metal bracket on one edge and the other just goes through this piece in the hole on the other edge with no metal bracket. I will see if the one that holds the bracket can work with this.
So I did pull one from the 4 door and if necessary it can be used but it is designed to go through the glass and the metal so is loose on the glass. Also the hole is slightly larger . I can fix that but if I could find a source for the correct one I woul
