bayyum
i would go with 750 if i were you, 650 is better for modified motors, and you said you were running stock
I'm curious as to why you think Demons are a pain to deal with? They are almost the same carb as a Holley or a Quick Fuel. 4 corner idle, power valve, double pumper, seems the same at least. Never had a pain dealing with mine.
dgc333. thanks a lot for the tip, that helps a lot and like i said the majority will be street driven with a little fun track time so i think i'll go for the 650. thanks again
dougie800, thanks for the tip, i wish i had more to spend on a carb. but unfortunaly i'm on a fairly strict budget.
What CFM is a Thermoquad carb which came stock on a lot of mopar motors such as 318s?
800's-930cfm, good mention, and it really depends on the tune and transition circuit on weather it'll work 'better' or not.
If you tune for, the bigger carb will make more power before 6000 rpm at any point from full advance. jmo
You can't compare a Thermoquad spread bore carb too a square bore carb. The primaries are tiny and the secondaries never fully open on a stock or mildyly modified motor. Those big carbs worked only because of the small primaries.
CFM......cubic feet per minute, a measurement of the velocity at which air flows into or out of a space. I was talking air not fuel... the fuel can be adjusted.
I'm not going to argue with you on this. Run the small carb I really don't care. I would take the larger carb (750) on a 408 come race night everytime. Don't believe everything you read.
http://www.forabodiesonly.com/mopar/showthread.php?t=75159&highlight=carb
CFM is volume of air not velocity.
We are talking about a 360 not a 408 and we are talking about a street car that might go to the track once in awhile. I will take a carb that will give me the best response in the rpm range I am going to use it the majority of the time and for a 360 that won't see the high side of 6000 rpm that is something in the 650 to 700 range.
No problem. I have thought about going to a 750cfm but, like the saying,"why fix it if it's not broken." At the track my Duster gets in the high 13's. That is with a 321 gear. I'm sure I could drop my time a little with a higher gear.i was talking about a 360 but someone got talking about a stroker 408???
Thanks for the tip Galactic eyes your build and usage sounds nearly identical to what i will be using and it sounds like you've had good luck with it. thanks again!!
I have a Eddy 600cfm on my slightly moded 360 with my total timing set at 36 degrees. I have great idle with excellent throttle response. The 600cfm seems to be a good match for my application. Which is an Airgap intake, Crane cam and the heads have been cleaned up. The block also has been bored .30. All of this going to TTI headers and X-pipe.
Like everyone has said, It depends on what you are going to do with your car. My car sees mostly street use with some track time.
As far as I know nothing has been done to it. The 360 had a Thermoquad that the previous could not get to act right. He had pulled the 600 off of his Montecarlo. It's been on there ever since.How is your carb set up if you don't mind me asking? The 360 in my Duster sounds fairly close to yours, but with the 600 Eddy AFB I have, it has a nasty ping when it gets up in the revs. I have a 650 Holley double pumper that turns the car into an powerhouse, though the AFB is much easier to drive.
