I bought the earliest radiator that Autozone showed in the catalog (~1971) for my 65 Dart 273. That was before I got good at ebay and craigslist. Might be for a slant since a 1.5" lower tube. I put in the alum water pump (w/ new timing chain cover), but caused other problems. Can no longer use the TRW p.s. pump and had to change to a Federal pump (w/ after-market brackets ~$70). The alum pump is 1" thicker, so could barely fit a Summit nylon fan. Pulley changes required too.
Today, I would have kept the cast-iron w.p. and looked for an alum radiator w/ hoses in the right place. The upper hose location depends on if you will have AC and what type compressor. I would only put in a Sanden today, no 50 lb RV2 for me.
