66 Barracuda factory front sway bar bracket mounts....
Miranthis
Shawnee, Kansas
Attached are pics of the sway bar brackets that I just took off my 66 as we got it torn down for the rotisserie. It does have the code 368 HD Suspension, so these are factory. Is this the way the brackets are supposed to look? It looks like they may have been scrunched at some point and repaired. If you have a good pic of the way the bracket is supposed to look my metal guy wants to make sure we put it back the way it was supposed to look. I found a thread from 2021, but it looked like that guy had modified the brackets to use another bushing. Thanks in advance.
Yep, just like mine I bought from a great member and friend here 12 years ago, 66 barracuda sway bar is now on my 66 sedan.
Thank you @cosgig
VICTORIA is a much better handler now
Yours look a bit beat up, but, they're not a precision parts, so, being a bit crude is not unusual. Side view should look a bit like an A shape and symmetrical, with the legs of the A flared out a bit below the cross piece.
