highwaystar
This is an original 273 4spd 4 barrel car that was turned into a drag car in 1973. It never had a cage or has never been tubbed. Just ran as a class car, later just running as a 12 second bracket car.
It currently has a 1970 340 motor and a 727 automatic transmission with a 4000 stall converter and an 8 3/4 rear with Moser axles and a 4.56 sure grip differential.
The interior was packed away in 73, and I recently installed the original drivers seat. The passenger and rear seat have no tears. There are a lot of boxes of original interior parts, except for door panels. Citron gold interior, and the exterior was an original light green as well.
This car ran US 30 in York, PA in the 70's under the name Mystic Mopar up until the late 90's when it was painted the current color.
I can't guarantee all the interior is there, but there is a lot, including a set of real nice rocker trim. I also have the original Radiator.
I ran this car last week at Skyview dragway in Oswego, NY. High altitude it ran an 8.25 on the 1/8 mile track. Motor has less than 50 runs on it.
I just dropped a thousand in a new cam, lifters, valve springs, Viton seals, resurfaced heads, pushrods, and ran only 3 runs on this new cam.
I will sell as is for $5500. or as a roller, less motor and Transmission for $2500.
I also have the matching set of Cragers for the rear, if you would rather have them.
New 5 gallon fuel cell with 1/2 fuel lines.
PM me if your interested. Car is located in N.E PA 18630.
I have a clear PA title in hand.
:burnout:
:burnout:
