66 cuda cargo carpet install
mbrooks573
Active Member
Atlanta, GA
Just bought a 66 cuda formula S. Prior owner put in new carpet in the front and rear seats but didn't get around to replacing the carpet in the rear hatch. Anyone know how difficult it is to install carpet along the rear fenderwells in the cargo area? Legendary has pre cut pieces for the rear area so I thought it couldn't be that bad. Thanks!
It's pretty straight forward, I started at the top of the wheel wells and tucked them in nicely there and left all the cutting to the bottom where the chrome strip was. Make sure you use plenty of contact cement on both sides, and be prepared to contort yourself like a magicians helper to get back there. I would also suggest that you do it in the shade or inside...it gets pretty hot back there!! Geof
