I will only be on the passenger side fender....there isn't one on the drivers' side. If it's missing and the holes are filled, open the door and look forward to the back side of the fender where the Pentastar should be. You'll probably see some bondo squirting through the original holes. With carefull measuring, you should be able to reopen those holes and mount the emblem without damaging the paint.
