66 dart disk brakes
alaskadartgt
Member
fairbanks
Looking to add disk brake to just the front of my 1966 dart gt. i have decided to
stick with the original 5x4 lug pattern. Any suggestions on what company to go with?
Since you're keeping the small bolt pattern, just get the factory Kelsey-Hays set up, problem solved.
The "just" in post #2 for K-H brakes is a very big and expensive step, but would be original for your year.
Easiest is Scarebird or Wilwood, since you bolt parts to your existing spindle, assuming your ball joints and bushings don't require replacement anyway. Scarebird is much cheaper and parts will be easy to find in the future.
