[WANTED] '66 Signet A/C Control
Mal Trull
Member
Stratford Australia
Rating - 0%
0   0   0
Hi. Looking for an a/c control for a 1966 Signet. It is the 5 button and single lever unit.
Or even a later one I could maybe adapt??
You can likely use any 5 button but the hutton appearance nay not be correct for a 66
They don't all operate the same. I would try to match the number stenciled on the control. What's wrong with yours? I've repaired a few of those in the past. If it's just the plastic rivets have broken on the back, that is a fairly simple repair. Broken vacuum nipples are repairable too, but, a bit tougher to do. If the button sockets or internal slides are broken, you need either a new control, or a core to use as a donor for the parts you need.
If a different five button switch is used the cars wiring will need to be updated to work with the switch. If I was spending your money I would buy a new five button switch and update the wiring.
