[Found!] 66 Valiant 273 A/C Compressor Idler Pulley Assembly
DaKineA
My 66 Signet
California
Rating - 0%
0   0   0
Re posting just in case someone missed it or can lead me to a find
Looking for the Factory A/C Compressor Idler Pulley assembly.
Need bracket, pulley, and hardware if available....
Diagram below shows the parts needed. I have the Idler "Roller" Pulley and Bracket. Need the Compressor Idler bracket and pulley...final piece to a long search...can anyone help me please?
I might have some. I'll look for you tomorrow night.
No hurry, just anxious as you would expect. I have the Idler bracket and pulley all cleaned up and ready, but need to research and hopefully find the bolts required to install it. If you come across those let me know. I am sure they are common threads etc but I do Not want to damage the original block trying to use the wrong hardware....
Totally appreciate this and again no hurry. We all have our own cars and lives to tend to:) Keith
Still looking for the Compressor idler pulley, no luck with wrecking yards so far....probably going to find a donor car....Thanks again!
I will check to see if i have that, i do have the roller idler pulley and bracket but need to check for the other one
Oh man that would be a life saver.....let me know and thank you for responding!!
Keith
Any luck? Thanks again... like I said final piece of the puzzle.....
Have!'t had any other replies.
Here are the 2 closest ones I have to your pic. If either one will work, pm me.
I found the parts I think....let you know if I still need your help. Thank you so much for your efforts! Keith
