[WANTED] 67 4 Speed Pedals and Manual Steering Col.
Hi
I've got a gas pedal, and clutch + brakes pedal assembly with Z bar and rods (I can also provide the clutch fork and throwout bearing in a few weeks) that i took out of my 68 Cuda 4 speed. All the bushings and bearings are new and it's all been powdercoated matte black last year. I also have the framerail bracket that you need to weld to fit your Z bar.
The only thing I cant provide is the main bracket onto which you attach the steering column as it is still (and will remain) attached to my steering column :)
I can get you photos if you want.
Ciao
Tony
