67 & 68 Barracuda Dash Pads
pastortom1
Zephyrhills, Florida
Is there a difference in the top section of the pads from 67 to 68 ?
There are pad overlays available for a 68 (which looks to be the top, and bottom as well.like a full wrap around)......My 67 is just steel around the bottom like other A's.......
Will the 68 top section fit the 67? Yes? No? Don't give a hoot? What?
Yes, there are differences! The 67 pad has a ridge across the top and is longer on the sides, the 1968 Pad is flat across the top (like the 69-on) but unlike the 69+ pad, it has shorter sides with unfinished bottom that match up to the bottom pad.
Will it physically bolt on? Most likely, but will not look or fit correctly.
