[WANTED] 67-68 drivers Barracuda partial fender
68cuda05gto
north platte
If someone has a drivers fender that is destroyed but the front portion is still good then I’m in need of it. The front corner on mine is smashed in but if I can get the front off another then I can weld it on.
I have this if you think it good enough. Looks and sounds solid except for the rust holes in the pic. Free plus the ride.
Where would you like me to cut it at? Do you want the part that bolts to the radiator support or just in front of it? It will take a couple days.
