67-69 cuda body style
matt_19
New Member
are all the 67-69 cuda fastbacks the same body style or are there differences? thanks
There 3 differant body styles used in those years. fastbacks, Notch Backs and Convertibles.
Welcome aboard Matt. While Adam already answered that there are 3 identical body styles, fastback-notch-`vert, they each have unique features for each model year.
67: No side marker lights
Grill is a square grid
Thin cast metal trim centered between the tail lights
Small reverse lights on either side of license plate
Plastic window moldings press into window rubber
Grooved hood inserts
68: Round side marker lights
Grill has vertical ribs
Trunk trim is an upper & lower aluminum piece
Reverse lights are part of the taillights
Stainless steel trim for window moldings
Hood inserts are allen socket heads with ribbed
or engine size 340 or 383 centers
69: Rectangular side marker lights
Grill returns to square grid
Shape of grill changes from (0=X=0) to (0=Y=0)
Trunk trim is wide aluminum panel from side to side
Larger reverse lights return to either side of license
Flat hood without inserts
Center of the hood peak has a pronounced hump
This should get you started in identifying the different model years. I didn't get into details such as idler arms, fuel tanks, or engine sizes per model year for the sake of simplicity. If you need more refinded details, ask away.
There's a lot of knowledge on this board:thumrigh:
