[SOLD] 67-69 stainless steel, 8 ¾ housing brake line kit
physixx
Edison, NJ
I have for sale what looks to be a new stainless steel, 8 ¾ brake line set from SSTubes #YRA6702SS.
YRA6702SS- 67-69 Mopar A-Body, w/ 8 3/4 inch Axle; 2 Piece Rear Axle Brake Line Set; Stainless
These brake lines fit the 67-69 A-body 8 ¾ housings with the flexible hose T-connection closer to the center of the housing. The only issue with this set is that on the short line, there appears to be two cuts in the line but don’t go all the way through. Not sure what the deal was with these two cuts though. I am including the fittings that will fix the issue without any problems. I would like to get $15 plus the shipping for everything.
Ken
Edison, NJ
