[WANTED] 67-69 Turn signal switch with wiring
Just buy a new one, the old ones are usually brittle and will break soon if not while you mess with them...
Not long ago I had what had tested to be a good used signal switch in my hand. I decided I would clean it a little with compressed air. A frail little steel wire spring beneath the horn contact was rusted enough that it took flight in so many pieces/disappeared. It wouldn't be easily replaced either.
Google Daniel Stern Lighting for a new quality built switch assembly.
I have one also. Stay away from the aftermarket ones as most are junk in a short amount of time.
