[WANTED] 67-69 turn signal switch.
clementine
Flight risk
Emerald city
Hey FABO,
Im looking for a nice turn signal switch with the pigtail OR information of what you guys are running/happy with. Floor shift car if it matters. Need to get the lever as well. I hear that the re-pop stuff is questionable. My current has a few issues and I think I could do better, hopefully for not a lot of cashola? Am I dreamin?
tell him he's dreaming the castle - Google Search
thanks FABO
Hey FABO,
thanks FABO
I bought one a few years back off eBay. It worked, but was missing the plastic plug on the end. I ended up using one from a 70s truck. No problems so far.
Hey FABO,
thanks FABO
I have the original one out of my 68 fastback , I thot it was bad after the total rewire and replaced it , turned out to be a lower contact in the lower end that I switched from the E Z chevy plug in to the mopar harness plug , that I had in the wrong position .
U would need to graft the lower steering column plug onto it , no biggee.
I carefully removed one from a 67 column intending to ship it the the UK for a member here. Tested it, good to go. Then just before boxing I decided to use compressed air to blow some of the dust/dirty off it. The tiny spring under the horn contact was so rusty that it took flight. I could only apologize to the buyer. Glad it broke here instead of there. My point being beware of 50 year old parts.
Yes, agreed, i am rewiring the car. Using old but nice parts can be a bit Russian roulette-ish. So, what did you guys use to replace? Did you use re pop? If so, where did you source it? I'm tryin my best here and although i know ill have to go bavk and redo some of this stuff, im hoping to minimize these situations.
Thanks fellas.
Hey FABO,
thanks FABO
Do u have a part number? I have a lot of switches inventories
Sorry SGB, I got distracted. My switch is in driver condition and probably usable. I do not know the OEM part number, and I dont know if there is a NOS out there. My question is, where are you guys getting this part from? Is is a quality part? Or do you just get the EBAH one and call it? Again, apologies for the lack of response.
Thanks!
