67 - 72 Door Hinges
I have a decent pair from the passenger side door of a 67 Dart and can most likely take all 4 from a 72 Duster that I'm parting out. I'm guessing that they are all the same. Let me know.
Ken
Edison, NJ
[email protected]
Thanks for the quick responses. Just a couple of questions to both of you, are they ready to use or will they need to be rebuilt? And how much are you looking to get for them? Thanks again!
They are ready to go. You may just want to clean them up a bit is all. They're still on the car and when I opened the doors and pulled up on them, there was very little play so the pins are good. I'll include the attaching bolts if you need them.
Ken
I live in Mpls and have a few sets of A body hinges---Your more than welcome to come over and pick out a good set
Thanks to all who responded. I was out in Annandale for work found a yard with a set of good hinges. $25 for the set.
The lowers are the same left to right.
The uppers will work the same way, but the pin is reversed.
4 door fronts are also compatible with 2 doors.
Mark.
