If you need more pictures please pm me your email, for some reason all the pictures would not load. Selling a kelsey hayes small bolt pattern(4inch) disc brake set up and sway bar with lower control arms.The rotors are no good and will be removed. These still have the brackets on the back that are usually missing, the ones that hold the ends of the brake lines in place. The calipers slide free but should be rebuilt or remans bought. These were removed from a manual disc car. I have the proportioning valve and brake rod which are also included in the sale. Backing plates are in decent shape. The lower control arms and sway bar are for 67-72 abodys. The arms will need all new bushings and balljoints. Asking $400 plus the ride.
